STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
CMSIS DSP 1.16.2 || NUCLEO-H7S3L8 || H7S3L8
STM32Cube IDE Version: 1.17.0  CMSIS-DSP 1.16.2 NUCLEO- H7S3L8Below  a suggested solution for those using CMSIS-DSP 1.16.2 together with NUCLEO-H7S3L8 (this may be generalized to other similar configurations) as I 've been myslef browsing a couple of...
AudioDev by Associate II
  • 1345 Views
Resolved! Firewall blocking ST Login?
I can't login into ST to download packages via CubeMX/CubeIDE. The wheel turns forever, no matter what proxy settings I choose. The pack downloader works - I just can't log into ST which is a pitty.Which url does my corporate IT whitelist?See similar...
JKapp.1 by Associate III
  • 1364 Views
Cube_IDE color
Hello, Is it possible to change the color of the tabs on Cube IDE? See attachment.Best regards.Sebastien.
PSEBA.1 by Associate II
  • 897 Views
Resolved! STM Cube IDE installation problem in RHEL
I am facing an issue while installing the cube ide in  my rhel 9.2 version,the exact problem was when i try to run the executable file and going through the instructions ,after agreeing the licenses and the folder which contains .rpm files is deletin...
undefined reference to `SEGGER_RTT_ASM_WriteSkipNoLock'
Hi,i am trying to port FreeRTOS to my STM32L152RCT6.i did it successfully.but when i am trying use segger debug tool.i am facing issue like this  18:09:25 **** Incremental Build of configuration Debug for project freertosporting **** make -j4 all ar...
chaithu by Associate II
  • 2973 Views
STM32CUBEIDE inc src hidden
I wanted to check out the HID Master USB example from ST for my STM32H7B3I-DKIt would not compile, forcing me to upgrade my CubeIDENow it compiles, but inc & src folders do not appear in Project explorer.  They are there on the hard diskThe inc and s...
BBrow.2 by Associate III
  • 1300 Views
