2019-11-01 3:09 AM
Current default settings for indentation:
Code generator: spaces only, 2 spaces per indentation level
Code formatter: tabs only, 4 spaces per indentation level
This quickly results in an indentation chaos if the default code formatter layout is not changed.
Please align the default settings to something reasonable!
(In the meanwhile, go to Preferences/C,C++/Code Style/Formatter, hit 'Edit' , set 'Tab policy' to 'Spaces only', 'Indentation size' to 2, 'Tab size' to 2, Edit the Profile name and hit 'OK' to at least be concise with the code formatter output.)
