2023-06-20 3:32 PM
can some share dts configuration which allows you to bring up the PWM, timer etc?
I do something like
pwm_regulator {
compatible = "pwm-regulator";
pwms = <&{/soc/timer@40002000/pwm} 3 500000 0>;
regulator-min-microvolt = <1016000>;
regulator-max-microvolt = <1114000>;
regulator-name = "vdd_logic";
/* Voltage Duty-Cycle */
voltage-table = <1114000 0>,
<1095000 10>,
<1076000 20>,
<1056000 30>,
<1036000 40>,
<1016000 50>;
plus
&timers4{
status = "disabled";
/* USER CODE BEGIN timers4 */
/delete-property/dmas;
/delete-property/dma-names;
/* USER CODE END timers4 */
pwm{
pinctrl-names = "default", "sleep";
pinctrl-0 = <&tim4_pwm_pins_mx>;
pinctrl-1 = <&tim4_pwm_sleep_pins_mx>;
status = "okay";
/* USER CODE BEGIN timers4_pwm */
timer@3 {
status = "okay";
/* USER CODE END timers4_pwm */
but nothing appears on the boot log and no timers devices are available in /sys/bus/iio/devices and PWM itself.
Why is not working, a similar solution working on stm32mp15x.
2023-06-21 1:03 AM
OK I think I found a solution, my mistake
&timers4{
status = "okay";
compatible = "st,stm32-timers";
pwm{
status = "okay";
compatible = "st,stm32-pwm";
timer@3 {
compatible = "st,stm32h7-timer-trigger";
status = "okay";
};rest can be found on
2023-06-21 1:03 AM
&timers4{
status = "okay";
pwm{
status = "okay";
timer@3 {
status = "okay";
