2020-12-10 9:21 PM
I want to know what "st-image-xxxxx" parameter mean.
Especially, I want to know what name of xxxxx (for example "weston") means.
Is the name of xxxxx related to the name of some config file?
For example, if I changed the name of xxxxx to any name from weston, Are output files by bitabake influenced?
Best Regards,
H. Masuda.
2020-12-11 3:58 AM
Its the name of the recipe file in layers/meta-st-openstlinux/recipes-st/images/. So you might look up the recipe and see what else is possible or change the recipe according to your needs (Best done in your own layer).
2020-12-11 3:58 AM
2020-12-15 6:17 PM
Hi @KnarfB
Thank you for your reply.
I understood very well.
So, when we create our own machine, Should we create our own layer(meta-***), and create recipe file in our own layer instead of using "weston"?
H. Masuda
