STM32 MPUs Products and hardware related
Resolved! SMT32MP1 MCU as Power Management Unit
Hello.I want to use MCU (Cortex M4 core) as PMU for MPU (Cortex A7 core).Is it possible to use it in this way?For this I need the following:It's better to start MCU firmware from another source (not SRAM) - from non-volatile memory. Is it possible?Sw...
alexey.b by Associate II
  • 1706 Views
Resolved! Engineering mode and CA7 secure state
In RM it is stated that in Engineering mode (BOOT pins at 3'b100) the MPU re-opens CA7 secure debug.I boot in that mode, then halt in openocd:stm32mp15x.cpu0: hardware has 6 breakpoints, 4 watchpoints > halt stm32mp15x.cpu0 rev 5, partnum c07, arch f...
Is it possible to compile LinuxPTP with the OpenSTLinux Developer SDK or will OpenSTLinux eventually include LinuxPTP?
I am having issues cross-compiling LinuxPTP. I've been able to work my way through some of the cross-compiling issues but now I am stuck with the compiler searching for crt1.o, crti.o and crtbegin.o files. Any help would be appreciated.
Resolved! linux performance
I just got my dk2 kit, played with it a little bit, but the performance is so bad. it takes a lot to boot ~30sec and after that it is unresponsive, you click something, then several seconds later something happens. Is this considered normal, or it is...
Resolved! OPTEE, trusted APPS
I'm interested in learning about TF-A, OPTEE, are some demos concerning these topics available?Is it possible to debug the CortexA core, through the embedded ST-LINK? I mean working solution, not in theory?What would be limitations debugging very ear...
4 questions about "st-example-image-qt"
Hello,I have 4 questions if you have time to answer, I would appreciate it very much.I prepared st-example-image-qt image. But there isnt any terminal like weston image. Should I run any other command before bitbake in order to have all the tools pac...
IYetk by Associate III
  • 2221 Views
