2025-12-02 8:54 PM
The below device tree is for RTL8211F-CG, but i needed help with configuring DT for DP83867IRRGZT, which DT binding should i refer, and if possibly have a DT configured for DP83867IRRGZT, do share it.
Hoping for a quick reply,
Thanks in advance.
ð1 {
status = "disabled";
pinctrl-0 = <ð1_rgmii_pins_a ð1_mdio_pins_a>;
pinctrl-1 = <ð1_rgmii_sleep_pins_a ð1_mdio_sleep_pins_a>;
pinctrl-names = "default", "sleep";
phy-mode = "rgmii-id";
max-speed = <1000>;
phy-handle = <&phy1_eth1>;
st,eth-clk-sel;
snps,ext-systime;
mdio1 {
#address-cells = <1>;
#size-cells = <0>;
compatible = "snps,dwmac-mdio";
phy1_eth1: ethernet-phy@4 {
compatible = "ethernet-phy-id001c.c916";
reset-gpios = <&gpioj 9 GPIO_ACTIVE_LOW>;
reset-assert-us = <10000>;
reset-deassert-us = <80000>;
realtek,eee-disable;
reg = <4>;
};FYI, im working on a custom board with stm32mp257fai3 chip with custom ethernet
2025-12-11 2:23 AM
Hi @sanjaysb
Did you check wiki documentation starting from Ethernet overview - stm32mpu
It might gives you useful information.
Olivier
