2022-04-28 4:55 AM
2022-04-28 3:12 PM
Check data sheet for your LDO, if Logic High within 3.3V.
I wouldn't connect uCPU directly with enable pin, better to set a resistor in series, to stay safe in case of whatever may happened to LDO - power domain is always most vulnerable part of the circuits. 10k - 100k
2022-04-28 5:26 AM
If the logic level was "unstable", the output would be useless.
2022-04-28 6:18 AM
Yes, the output will stay high if you set it high, and low if you set it low, until you change it, or the chip loses power or resets.
2022-04-28 6:45 AM
Perfect thanks!
2022-04-28 3:12 PM
2022-04-29 12:29 AM
Sounds reasonable now that you said it! Thanks for the tip:)
