2021-08-24 5:39 AM
Please advise on mounts / bga-to-pin adapters or sockets that I can mount on a pcb so that I can still use this chip. Thanks in advance.
2021-08-24 1:54 PM
You could use a BGA breakout board, but that kills your minimum trace length and makes decoupling caps not ideal.
https://www.proto-advantage.com/store/product_info.php?products_id=4000033
The best solution would be to use a multi-layer PCB. Can't imagine the extra headache in an adapter is worth it.
