2024-02-05 7:18 AM
I encounter the following error when connecting STM32WB15 to ST-Link V2.
Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication
only VDD,GND, and SWIO and SWCLK pins connected..
package is ..UFQFPN48
what is problem..?
2024-02-12 9:58 PM
i solved this problem... Proble is SW Fequency... Low frequency is working..
Thanks..
2024-02-05 7:35 AM
2024-02-05 7:49 AM
@Erdincca wrote:If your product embeds Debug Authentication,
Does it?
If 'yes':
@Erdincca wrote:please perform a discovery using Debug Authentication
did you do that?
@Erdincca wrote:only VDD,GND, and SWIO and SWCLK pins connected..
Have you tried adding Reset?
2024-02-05 9:46 PM
yes customboard. i use stm32cubeprogrammer. output voltage 3.3v. original stlink v2 use..
2024-02-06 6:31 AM
Perhaps a schematic error. Perhaps a hardware error.
2024-02-12 9:58 PM
Thanks..
2024-02-13 1:14 AM
@Erdincca Good to hear it's solved.
Now please mark the solution - so that others who come here with the same problem can find it.
