2025-05-21 10:01 AM
I made the PCB for stm32wb09kev6 myself and downloaded the p2p_server example program. I changed the LSE clock used in the example program to LSI and added an LED to indicate whether a Bluetooth connection is established. The Bluetooth can be scanned, but there is a problem with the Bluetooth connection part. The Bluetooth connection will be established briefly and then disconnected quickly (manifested as the LED turning off first and then on, and an error "an error occured during connection" will be reported in ST BLE ToolBox). The debug output is as follows:
Success: aci_hal_set_tx_power_level command
Success: aci_gatt_srv_profile_init command
Success: aci_gap_init command
Static Random Bluetooth Address: fd:c8:e7:c9:5c:bf
Success: Gap_profile_set_dev_name - Device Name
Success: Gap_profile_set_appearance - Appearance
Success: aci_gap_set_io_capability command
Success: aci_gap_set_security_requirements command
Success: aci_gap_configure_filter_accept_and_resolving_list command
==>> End BLE_Init function
Services and Characteristics creation
Success: aci_gatt_srv_add_service command: p2p_Server
End of Services and Characteristics creation
Success: aci_hal_set_radio_activity_mask command
==>> Success: aci_gap_set_advertising_configuration
==>> Success: aci_gap_set_advertising_data
==>> Success: aci_gap_set_adtart
==>> Success: aci_gap_set_advertising_enable
>>== hci_le_connection_complete_event - Connection handle: 0x0801
- Connection established with @:8c:f8:c5:4c:f3:ff
- Connection Interval: 45.00 ms
- Connection latency: 0
- Supervision Timeout: 9600 ms
>>== HCI_DISCONNECTION_COMPLETE_EVT_CODE
- Connection Handle: 0x801
- Reason: 0x28
>>== hci_le_connection_complete_event - Connection handle: 0x0802
- Connection Handle: 0x802
- Reason: 0x28
Can anyone help me? Thank you.
2025-05-21 11:51 AM
Hello @JfSDK
The reason 0x28 of disconnection refer to "Instant Passed" error that is a common issue in BLE communication, particularly when dealing with Link Layer (LL) or Link Management Protocol (LMP) Protocol Data Units (PDUs). This error occurs when an operation that was supposed to happen at a specific "instant" in time cannot be executed because the specified time has already elapsed. This may be happened for different reason. Could you please try to connect your node to client node that have higher scanning time interval (try another app maybe the ST BLE Sensor or others) or use another board with the P2P client example with a high scanning interval.
Best Regards.
STTwo-32
