STM32WB doesnot advertise in debug and gives hard fault exception??
VJadh.3
Associate
Using STM32WB have both bootloader & application implemented. Whenever code is downloaded the application works fine advertises and performs intended function , however if application is put in debug it gets stuck & doesn't advertise . At this time PC points to some part of code in bootloader.
1 REPLY 1
Remy ISSALYS
Can you give more information about your setup ? Are you using P-NUCLEO-WB55 or a custom board ? Which application and BLE stack are you using ? And which IDE are you using ?
Best Regards
