2022-03-08 7:37 AM
Dear Community,
I'm using a P-NUCLEO-WB55 Board and Dongle, until now only with ST examples.
I'm trying to perform firmware update using BLE OTA (switching from BLE_HeartRate_ota to BLE_p2pServer_ota for example) and am facing a problem.
The same problem appears if I Use STM32 CUBE Monitor-RF on PC with P-NUCLEO Dongle or using STM BLE Sensor App on Android smartphone.
Here is my issue:
I can find my device and start an OTA update.
Flashing starts and very frequently, it suddenly stops, like if connection was lost.
I checked, I have a stable power supply.
Could you please give me any hint on how to proceed for debugging?
Thanks and best regards
2022-03-09 5:54 AM
First check if you have the latest firmware version on your board:
If you need to update your firmware download the latest release (available here https://www.st.com/en/embedded-software/stm32cubewb.html) and follow the instruction of this wiki page:
Then flash your board with BLE_Ota_reference.hex available in STM32Cube_FW_WB_V1.13.0\Projects\P-NUCLEO-WB55.Nucleo\Applications\BLE\BLE_Ota\Binary.
Download on your smartphone BLE_HeartRate_ota_reference.bin and BLE_p2pServer_ota_reference.bin files.
Take your smartphone with ST BLE Sensor application:
More informations about OTA process is available in AN5247.
Best Regards
2022-03-10 1:24 AM
Dear Remy,
Thank you for your quick reply.
I was working with FUS v1.2.0 and BLE Stack v1.12.1, so I tried to update to the last available revision v1.13.1, but the described problem remains and another appears.
Again, I'm working with ST Hardware, and ST binary files.
In addition, I have 2 P-Nucleo Boards and 3 dongles... what I describe here appears with whatever of them I use.
With v1.12.1, firmware update using Cube RF and Nucleo Dongle:
a) BLE_OTA -> BLE_HeartRate_ota : OK, no problems
b) BLE_HeartRate_ota -> BLE_P2PServer_ota : OK, no problems
c) BLE_P2PServer_ota -> BLE_HeartRate_ota : Error, gets stuck while flashing
With v1.13.1 :
a) Using Cube RF and Nucleo Dongle I'm even not able to detect the P-Nucleo Board anymore...
b) Using Android MobilePhone and ST Sensor App I detect the P-Nucleo Board
c) and start flashing. But again, there is an error, the app gets stuck while flashing
d) And finally I lost my P-Nucleo board... ST-Link tells me there is no device on target...
e) I tried to connect to the P-Nucleo boards with USB, but no FSU is detected.
So, I'm now unable to connect to my P-Nucleo Boards and really don't know how to come out of this.
Thank you in advance for your support,
Best Regards
2022-04-21 12:57 AM
Follow up from my last post:
I managed to reconnect my P-Nucleo Board, thaks to this post:
Howto:
Hope it helps
