2025-03-21 2:38 AM - last edited on 2025-03-21 2:54 AM by Andrew Neil
I am using the STM32WB15CC and encountered an issue when my program exceeded 112KB (0x1C000), causing the flashing process to fail. I noticed that the memory region starting from 0x0801C000 is set as a secure flash area.
I would like to know if it is possible to modify this secure flash area. If so, could you please provide guidance on how to make the necessary modifications?
2025-03-21 6:34 AM
Hello @hanyang
To optimize the available memory for a dedicated application, the linker file must be updated. But the end of available Flash memory address can be moved only up to the SFSA address.
Best Regards.
STTwo-32
2025-03-21 6:34 AM
Hello @hanyang
Best Regards.
STTwo-32
