2022-09-08 2:27 AM
In programming manual PM0271 - STM32WB BLE stack programming guidelines
In section 2.2
The correct formula should be : (2402 + k*2) MHz, where 0 ≤ k ≤ 39
The table 1 is not correct as well, it should conform to the formula.
e.g. Channel 10 = 2422 Mhz
Tested in hardware on NUCLEO-WB15CC using BLE_LLD_StartTone
2022-09-12 8:01 AM
Hello @Motla ,
I confirm that the (1) formula is not aligned with the values in table1 in the PM0271.
I reported this issue internally.
I will get back to you with more details as soon as possible.
Internal ticket number: 134452 (This is an internal tracking number and is not accessible or usable by customers).
When your question is answered, please close this topic by choosing Select as Best. This will help other users find that answer faster.
Kaouthar
2022-09-22 12:57 AM
Hi @Motla ,
I confirm that the correct formula is (2402 + 2*k) MHz, where 0 ≤ k ≤ 39,
Kaouthar
2023-06-20 7:46 AM - edited 2023-06-20 7:47 AM
Still not corrected in the Rev 7 - April 2023 release of the document...
