2026-02-19 12:07 AM - edited 2026-02-19 12:12 AM
Hi.
I want to use NUCLEO-WL55JC with 32MHz crystal, not TCXO. So i do following steps according to UM2592(User manual of STM32WL Nucleo-64 board)
I use LoraWAN_end_node project in STM32Cube_FW_WL_V1.4.0.
So i do following steps in configuration in CubeMX (also attach clock configuration)
But after that, NUCLEO board give me message MAC txTimeOut instead of success tx process. While i use TCXO, there is no problem to send tx and also connect to LoraWAN.
What can i do to use standard crsytal instead of TCXO? Because i want to use my custom board, but i stuck about crystal.
2026-02-19 3:05 AM
Sorry for my mistake. The problem was my fault. I could not solder the R39 properly. After soldering, it connect LoraWAN successfully.
2026-02-19 3:05 AM
