2021-08-04 7:34 AM
Hi, everyone.
Is it possible to build an application that supports all regional standards? AS923-1 / AS923-2 / AS923-3 together are of particular interest (depending on the setting, which is changed via the UART, for example).
2021-08-04 8:49 AM
There is no fundamental limit what you can implement, so yes, a multi-regional application is possible. But be prepared that a lot has to be done by you yourself
2021-08-04 9:34 PM
It's a pity. But thanks for the answer anyway.
