2020-06-09 10:17 AM
I follow the exact same procedure. I generate code, set GPIO and clock in Cube MX. Open the file in System Workbench. Initialize all the pins right.
I should be connecting the ESP8266 pins to the expansion board right ? This expansion board is connected to the nucleo using the SWD connector.
I feel like I'm missing a step. I ran the example data logger project which works fine on the sensortile.
