2021-01-15 6:27 AM
I have to design a wb55 firmware which expose one service with twelve characteristics, but using CubeMX there are no ways to add more than five characteristics for each service.
There is a tip to skip this limit (also modifying the CubeMx automatic source code) ?
Thanks in advance
2021-01-18 12:23 AM
Solved adding manually the characteristic and services, skipping the template create by CubeMx, and adapting the [service_max_attribute_record] parameter on aci_gatt_add_service.
