2024-02-05 3:39 AM
Curious regarding using ACI_GAP_SET_AUTHENTICATION_REQUIREMENT to change the fixed pin after already using a different pin key for a previous connection.
Would that work?
Any bad consequences?
2024-02-08 2:23 AM
Hi DS.4,
It's important to make sure that you are not in a connected state when changing the fixed pin.
This should work and not cause any problems.
Don't hesitate to let us know if it worked ;).
BR, Joé
2024-02-08 2:23 AM
Hi DS.4,
BR, Joé
2024-02-08 3:17 AM
Changing it after I complete bonding , and it looks fantastic.
So next connection does get to use the new key. So far so good!
thanks
