STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
Manual Calibration of HSE STM32WB nucleo?
So im trying to follow the 1:20h tutorial about how to setup BLE,narrated by ringo start's voice and i reach the part in which he refers to an inexisting .pdf file containing the links for info about HSE calibration.As cant find that .pdf he is refe...
Javier1 by Principal
  • 978 Views
STM32WB FREERTOS FUOTA not working
Hi,I try to set FUOTA with FREERTOS on NUCLEO-WB55 demo board.I start with the BLE_HeartRateFreeRTOS, I built it, flash it and all is ok.Then I flash OTA bootloader (I know it's working also cause I try to update with BLE_p2pServer_ota project and it...
PBOIS.1 by Associate
  • 1360 Views
Resolved! IPCC Memory manager channel (TL_MM_***)
Would like to have a better understanding on the IPCC memory manager channel.(Have read the AN5289 notes)Appreciate If you can shed more light on it.What is it purpose?Why do we have to clear it after some events?What are its memory parts purpose ? a...
DS.4 by Senior II
  • 1249 Views
STM32WB55 RTOS and LOW POWER MODE (STOPMODE2)
Hi All, I'm currently working on a project that uses the STM32WB5MMG module.I did a porting of one of the examples of the repository (BLE_Zigbee_Dyn) for RTOS and everything is working fine.Now I'm trying to put the MCU in STOPMODE2; a GPIO Interrupt...
Jonny by Associate III
  • 964 Views
STM32WB55 IPCC Shared Memory
Is there a document describing all the shared memory between CPU1 and CPU2?Looked at AN5289 , but did not find any memory table map.How does CPU2 know where to put the answers for IPCC CPU1 requests?I see a lot of "PLACE_IN_SECTION" in the code not k...
DS.4 by Senior II
  • 1145 Views
