STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
SX126x and STM32WL
In ST's documentation, great pains seem to be taken to avoid specifically identifying the Semtech SX126x radio implementation. ST consistently refers to it as a "sub-GHz radio." Why is this?
SWagn.1 by Associate II
  • 1009 Views
Problems with ADC in LORA Process
Hello,I have problem with ADC using in LORA Porcess on NUCLEO WL55JC1.I modified project PING PONG(from LORA) to MASTER and SLAVE, where SLAVE send to MASTER in periodicly time a voltage form ADC, when I use ADC in main, everything its ok, but when I...
MMoro.5 by Associate
  • 982 Views
Resolved! STM32WB55 for ZigBee protocol
I would like to send an image of size 320x240 pixels using ZigBee mesh to the intended node from coordinator. What is the maximum range of ZigBee in mesh configuration achieved with STM32WB55 with external SMD antennaWhat is the power consumption in ...
YSN by Senior
  • 2778 Views
Problem with continious working of BLE Core
Hello! At first I want to apologize for my bad english.I faced with the following problem.I have device with STM32L476 MC and STM32WB55CE. Input voltage around 4 V. This voltage go the the switching voltage regulator TPS63050RMWT. After switching on ...
STM32WB p2pServer example does not work?!
Hi, i watched the video (https://www.youtube.com/watch?v=WgsXMVZfoO8) from the getting started series. I followed the steps and everything worked til running the example. If I press debug everything starts and the led 6 blinks red and green. The cons...
TAust.1 by Associate
  • 930 Views
WL55JC1 idle power consumption much higher than expected
I'm trying to get the idle power consumption of down to a few uA, but I cannot get it lower than around 920uA which is all being consumed by I_SYS.Has anyone been able to get it lower?I'm using the DCDC and TCXO (as far as I know).I don't think it wo...
MWols by Associate
  • 1071 Views
