Hi,I'm trying to get the STM32WB custom BLE example working in low power mode with no success.Running the stock example from the latest version (1.15.0) with no modifications except the following in the app.conf:#define CFG_LPM_SUPPORTED 1#define CF...
2 years ago it happened that the controller turned to brick. I corresponded with technical support for a long time and I was offered to send the controller to the factory or representative. But since the case was a single one, I did not take advantag...
I've gotten my STM32WB55 into a state where CPU2 is booting into a "wireless firmware" area, but I think it's crashing when it starts. I can no longer talk to FUS inside CPU2:------------------------------------------------------------------- ...
I successfully implemented a service with different characteristics. However on the android side when I call getDescriptor()descriptor =characteristic.getDescriptor(UUID.fromString(CLIENT_CHARACTERISTIC_CONFIG)); CLIENT_CHARACTERISTIC_CONFIG = "00002...
I'm starting with the wb15. For this I followed the video series and currently I'm stuck at https://www.youtube.com/watch?v=lFDMBeJpib0&list=PLnMKNibPkDnG9JRe2fbOOpVpWY7E4WbJ-&index=15Even following every step in the cube setting I'm not getting any ...
In my testing, I programmed two NUCELO-WL55JC2's to communicate with one another. I found that I could only receive if the transmitter antenna was aligned and touching the receiving antenna.After further debugging, I traced the issue to the LPO.Using...
I've been experiencing an issue where sporadically the aci_gap_set_discoverable fails to start due to a command disallowed error (similiar to this) on the STM32WB50.For context: the device goes into sleep mode and wakes-up 100+ times per day. In slee...
I'm busy debugging the RF conditions around my LoRaWAN installation.I get a lot of variance in both RSSI and SNR (+-10dB/+-6dB) and am trying to find it's source.In the absence of an SDR and other equipment, is it possible to read and report RSSI an...
HiI just bought a B-L4S5I-IOT01A Discovery kit.Confession: I am completely new to ST, and I reckon I have a mountain of learning to do in a short time.However, I just read the blurb on the back of the kit and it essentially says: 1. Verify the jumper...
