STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
Resolved! STM32WLE55 - new created STM32CubeMX files not building
Hello, we want to use the STM32WLE55 MCU in the AI50H Module to build a Node to Node connection in a LoRa Network.So i used the STM32CubeMX Program to build an easy solution that includes only "UART", "SUBGHZ" and "SUBGHZ_PHY" modules. Goal is that i...
Draegi by Associate II
  • 3896 Views
プロファイルサブシステム QDID 122688 �?�内容�?�よ�??�?�?�り�?��?�ん。カスタムプロファイル�?��?��?��?�も該当�?��?��?��?�。
STM32WB5MMG�?�STMicro�?�ら�??供�?�れるLibrary,Driver,FUS_fw,BLE_Stack_full_fw,BLE_Otaを利用�?��?��?カスタムプロファイル�?�BLEを�?�載�?��?�製�?を開発�?��?��?��?��?�。�?�れを販売�?�る�?��?�?Bluetooth SIG�?証を�?��?��?��?��?�考�?��?��?��?��?�。QDID170767,160724�?�該当�?�る�?��?�?れ�?��?��?...
hueta.1 by Associate
  • 1476 Views
Implement clock synchronization - undefined reference to functions (STM32Cube MCU Package for STM32WL series 1.0.0)
Hi everyone,I use the  STM32CubeIDE 1.6.0 and the STM32WL package 1.0.0I am trying to implement the clock synchronization feature but I cannot get the application to be built.I enabled the with the following definition#define LORAWAN_DATA_DISTRIB_MGT...
_legacyfs_online_stmicro_images_0693W00000bhkuOQAQ.png _legacyfs_online_stmicro_images_0693W00000bhkuYQAQ.png
We have an STM32WL55 processor. The FLASH memory is divided for two cores: CM0PLUS FLASH (rx) : ORIGIN = 0x08020000, LENGTH = 128K CM4 FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 128K Everything works.
But we need to increase the memory for CM4, so we modified the files STM32WL55CCUX_FLASH.ld:CM0PLUSFLASH (rx) : ORIGIN = 0x08030000, LENGTH = 64KCM4FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 192KUnfortunately, it stopped working with this definition....
JHave.1 by Associate II
  • 1517 Views
