STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
How i can resend same uplink frame on gateway failure or off ?
Hi,im using a loRawan module based on STM32WLE5 chip.i would like to know how i can save an event to reTx it on the next uplink when i have my gateway off or during a blackout . im trying not to lose info .my Tx duty cycle is every 90 minutes or on b...
rib.1 by Associate II
  • 1084 Views
STM32WB55 Nucleo --- working with debugger and not without
Hello all....Looking for some pointers. I have an application I created in CubeMX/IDE on a WB55 nucleo board. I am using nRF Connect app on my phone as the Client. When I run the nucleo server application with the debugger connected all seems to work...
SWenn.1 by Senior III
  • 1755 Views
OTA FW Update not working, compatibility issues?
Hi, I have the following problem:I am developing Firmware for a device that has a STM32WB55VGY6 on it. Right now I'm in the midst of trying to get a OTA FW Update to work, but I'm completely stuck. Whenever I try to upload a .bin file via the BLE Sen...
MaZ by Associate
  • 1425 Views
How to use the stm32wbcc series
I want to know how to design a PCB board about stm32wb55cc serial ic ,and should it need a antenna​?If it need, what is the most suitable antenna to the ic?
TShen.1 by Associate
  • 882 Views
