STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
Roadmap for STM32WBA52CG and STM32WB55VG
Hi,I plan to use either STM32WBA52CG or STM32WB55VG. Looks like the WBA is newly released compared to the WB. Is the WBA replacing the WB, and WB will no longer be supported?Is there a plan to release a new package for STM32WBA with 68 pins?
How to use external SIM on B-L462E-CELL1
Hello members,Please let me ask about how to use external SIM on B-L462E-CELL1.I inserted the plastic SIM to external SIM slot on B-L462E-CELL1.Then, I set APN and confirmed it get ICCID from SIM.However, I dont make clear how to setup connect networ...
About MB1789 Direct tie config
Hello,i am designing a custom board with the stm32WL55.i saw the MB1789 schematic and design, and i need to know more about this configuration and what are the advantage and inconvenient ?in this design they don't have a switch and the same line is u...
malarab by Senior II
  • 2578 Views
Resolved! How to reboot a STM32WL from code?
Hi, I'm using a STM32WLE5CCU micro with FW_WL V1.3.0 library. I want to implement a feature that receives a downlink command from the Network Server and reboot the entire system like pushing a reset button will do.Once the command is received, is the...
NMeno by Associate II
  • 5714 Views
MCU - Suggestion
Hello ST!GOOD day,We are looking new MCU for VOIP [voice over Internet protocol] project that can handle Internet connectivity and Communications ADC, UART] [, LAN, WAN, FXS, FXO support]. can you suggest MCU's for best and available MCU.with Wi-Fi 5...
