X-Cube Touchfgx software on Mac
Avgerinos
Associate III
Hello
I am using a Mac. There is software support for stm32cude ide on Mac. But I would like to ask if there is support for Touchgfx application on a Mac.
On the website https://www.st.com/en/embedded-software/x-cube-touchgfx.html
I can not find a link to download the software for Mac.
Is there software support for Mac or any other way to run this application?
Thank you
1 ACCEPTED SOLUTION
Accepted Solutions
GaetanGodart
Hello @Avgerinos ,
There is no support for TouchGFX on macOS.
However, there is still 2 ways you can use TouchGFX on your Apple computer:
  1. Run TouchGFX on a virtual machine
  2. Dual boot your computer with Windows (install Windows as a startup option)
If this comment answers your question, I invite you to select it as "best answer".
Regards,
Gaetan Godart
Software engineer at ST (TouchGFX)
7 REPLIES 7
GaetanGodart
Hello @Avgerinos ,
Regards,
Gaetan Godart
Hello
Is there a plan for Mac support in the near future?
Thank you for your answer
Hello @Avgerinos ,
Not in the near future but we are thinking about it!
Regards,
Gaetan Godart
I do own a M3 MacBook Pro and can't dual boot into Windows. Do you have any other options, beside a second laptop or a virtual machine (which slows down development)?
Andrei Chichak
Lead II
In the beginning, STM32CubeMX only ran on Windows and Linux, but someone figured out that it was all just a big Java program and figured out that it ran perfectly well on Mac if you just pointed Java at the .jar file. Word eventually got out and within a reasonable time period ST started officially supporting Cube on Mac.
I have not tried this with TouchGFX, as I still have a few Intel Macs around that I use with Fusion.
TouchGFX is not based on Java, so it is not so easy to make it run under MacOSX. But at least you can get on with VMWare Fusion.
dshenoy
Associate II
Is there any guidance on how to get a small proof of concept or "hello world" solution working on the Mac OSX?
