2023-07-25 4:34 AM
I built a project from within TouchGFX and clicked the Run on Target button. Unfortunately, I forgot to plug STLink into my target board so programming failed. I connected STLink and clicked the Run on Target button again and it went and compiled ALL source code again before downloading it to my board - why does it do this ???
Andy
2023-07-25 5:19 AM
Hello @andy2399 ,
Pressing either "Run Simulator" or "Run Target" will start the process of compiling and starting/flashing from the beginning. In order to run a specific instruction, you can use TouchGFX Environment, which is an CLI tool. You can start TouchGFX Environment by searching for it in your windows search, or going to the TouchGFX installation folder/env/MinGW/msys/1.0 and running msys.bat
You can also see the instructions used by the TouchGFX Designer in the Log View section.
Hope this has answered your question.
2023-07-25 5:19 AM
Hello @andy2399 ,
