2023-05-03 3:45 AM
2023-05-24 7:05 AM
Hi @Community member ,
For LwIP_StreamingServer application :
Please note that the application available under STM32Cube_FW_F7_V1.17.0 package need a fix (An Internal ticket ID 142051 is already created) to be functional :
I hope my answer helps.
Mahdy
2023-05-23 3:43 AM
Thank you for your request,
Performance tests are in progress,
We will keep you updated as soon as we have your required information.
2023-05-24 7:05 AM
Mahdy
2023-05-25 12:05 AM
@Mahdy Sghaier
Thank you very much for your answer. i have other questions.
What is the cause of the drop in the FPS. i would assume its not the JPEG compression since the resolution is QQVGA (160*120) and according to AN4996 Application note page 31 it should be possible to compress QQVGA and maintain 30FPS unless you reduce the camera clock to that FPS for other reason.
Second question is what is the cause of the 1.5 latency on the VLC side?
is it from the VLC side and if it is then how can we reduce it?
Can we use other application?
Mahmoud
