2024-12-02 8:42 PM
I had 8-Gigabyte External EMMC Memory to store the images in my custom Board, as my internal flash for the STM32H745XiH6 microcontroller is only 2MB. How to store the images in the external flash (EMMC)? Should I need to change the linker scripts and .map files in the project? If it is, can you please explain it clearly?
2024-12-05 1:20 AM
2024-12-10 6:11 AM
Hello @Shivani ,
Have you been able to move forward with your issue?
If you did, could you select the comment that helped you the most as "best answer".
Regards,
2025-06-01 11:13 PM
hey @GaetanGodart ,
it will great help if you will share solution as i am too working on storing image files in eMMC!
