2025-09-01 6:44 PM
Framebuffer is RGB565,Can I make a dynamic bitmap of ARGB8888?
I made one by cacheable container and display the dynamic bitmap by a texturemapper but the image came out is not correct,something did appear on screen,but size and color not right. but if I change bitmap type to rgb565,the image show correctly,but with black background and no alpha ,not what I wanted. There is enough cache,I confirm the dynamic bitmap is created successfully on both type.I tried to display the dynamic bitmap by a Image widget,but the result is the same.
In this forum,I can see a solution,to register a LCD32bpp class and set it as Auxiliary LCD in the hal.
But I didn't found any thread on this subject.
How to use off screen rendering of a textarea in a... - STMicroelectronics Community
Can I get any help from any @st guys?
2026-02-17 7:16 AM
I am not able to reproduce the compile error. I have tested with the STM32H7S78-DK TBS. Have you tried cleaning your project in STM32CubeIDE?
Alternatively, can you share your project?
Best regards,
Johan
2026-02-17 3:33 PM - edited 2026-02-18 3:41 PM
Hello @JohanAstrup
I update designer V23.2 to V26. The compile error disappear.
I don't know how it works,but at least it works.
Thanks for your help.
Best Regards
amb
