2022-01-26 3:52 AM
Slide menu should be expanded from top also with swipe down gesture.Also slide menu contains a slider widget. I am trying to achive this with SwipeContainer and SlideMenu but can't expend the Slide menu
2022-02-18 1:17 AM
Hello manto.1,
You can found an example of what you need in TouchGFX Designer. It's the "Swipe Container Example".
/Osman
