2019-11-06 11:03 PM
When I want to run a touchgfx example (of demo) in designer, compiler give me error like follows.
Run Simulator
Generate
Done
Generate Assets
make -f simulator/gcc/Makefile assets -j8
cannot load such file -- lib/emitters/typed_text_database_hpp
an error occurred in converting texts:
Cleaning generated files from generated/texts and generated/fonts.
make[1]: *** [texts] Error 1
generated/simulator/gcc/Makefile:229: recipe for target 'texts' failed
simulator/gcc/Makefile:32: recipe for target 'assets' failed
make: *** [assets] Error 2
Failed
FailedWhat can I do about that?
2019-11-07 2:51 AM
Highly strange. Can you try creating a new application using the UI templates that are failing for you? Just to be sure it's not something with the application itself - Designer bootstraps the application with libraries, headerfiles, etc when generating code so that each application is self contained.
/Martin
2019-11-07 3:09 AM
I am tried now create new several demo and blank ui. All give error like this; (I copied this one from blank UI's detailed log)
Run Simulator
Copy Framework
Copying TouchGFX framework version 4.12.3 to C:\TouchGFXProjects\MyApplication_1\touchgfx
Done
Generate
Wrote config/gcc/app.mk
Wrote config/msvs/Application.props
Wrote generated/gui_generated/include/gui_generated/common/FrontendApplicationBase.hpp
Wrote generated/gui_generated/include/gui_generated/common/FrontendHeapBase.hpp
Wrote generated/gui_generated/include/gui_generated/common/SimConstants.hpp
Wrote generated/gui_generated/include/gui_generated/screen1_screen/Screen1ViewBase.hpp
Wrote generated/gui_generated/src/common/FrontendApplicationBase.cpp
Wrote generated/gui_generated/src/screen1_screen/Screen1ViewBase.cpp
Wrote generated/simulator/gcc/Makefile
Wrote generated/simulator/include/simulator/mainBase.hpp
Wrote generated/simulator/msvs/touchgfx.props
Wrote generated/simulator/msvs/touchgfx_prebuild.targets
Wrote generated/simulator/msvs/touchgfx_sdl2.props
Wrote generated/simulator/src/mainBase.cpp
Wrote generated/simulator/touchgfx.ico
Wrote generated/simulator/touchgfx.rc
Wrote generated/simulator/touchgfx.res
Wrote gui/include/gui/common/FrontendApplication.hpp
Wrote gui/include/gui/common/FrontendHeap.hpp
Wrote gui/include/gui/model/Model.hpp
Wrote gui/include/gui/model/ModelListener.hpp
Wrote gui/include/gui/screen1_screen/Screen1Presenter.hpp
Wrote gui/include/gui/screen1_screen/Screen1View.hpp
Wrote gui/src/common/FrontendApplication.cpp
Wrote gui/src/model/Model.cpp
Wrote gui/src/screen1_screen/Screen1Presenter.cpp
Wrote gui/src/screen1_screen/Screen1View.cpp
Wrote simulator/gcc/Makefile
Wrote simulator/main.cpp
Wrote simulator/msvs/Application.sln
Wrote simulator/msvs/Application.vcxproj
Wrote simulator/msvs/Application.vcxproj.filters
Done
Generate Assets
Writing generated/images/include/BitmapDatabase.hpp
Writing generated/images/src/BitmapDatabase.cpp
No such file or directory - touchgfx/framework/tools/textconvert/Templates/TypedTextDatabase.hpp.temp
Generating generated/fonts/src/GeneratedFont.cpp
Generating generated/fonts/include/fonts/GeneratedFont.hpp
Generating generated/fonts/include/fonts/CachedFont.hpp
Generating generated/fonts/src/CachedFont.cpp
Generating generated/fonts/include/fonts/FontCache.hpp
Generating generated/fonts/src/FontCache.cpp
Generating generated/fonts/src/ApplicationFontProvider.cpp
Generating generated/fonts/include/fonts/ApplicationFontProvider.hpp
Generating generated/texts/include/texts/TextKeysAndLanguages.hpp
Failed
Failed
2019-11-07 4:33 AM
But this a different error now, right? Can you try sending me the project?
/Martin
2019-11-07 4:50 AM
2019-11-07 5:03 AM
@Martin KJELDSEN Let me say this, I can generate code my another project with my computer. I get error when create new project with designer only.
Another thing, I was the one who got the error we talked about it before in this topic. Same computer, same program, different errors :beaming_face_with_smiling_eyes:
And last thing, I use computer in Turkish, I am saying for you say some thing about that before.
2019-11-07 5:22 AM
Okay, it seems there may be more issues related to Turkish than i first thought!
/Martin
2019-11-07 5:34 AM
When is this language problem solved? This problems really slow down our work.
2020-10-27 8:06 AM
Hı
move your project file to orijinal workspace folder
