Cutout irregular shape image
Trevor Jones
Senior
I have a product image that is not square,
how can I cut out the white background, within GFXdesigner?
1 ACCEPTED SOLUTION
Accepted Solutions
Martin KJELDSEN
Chief III
You can't from within the designer, but you can use your favorite image editor to replace white with full transparency (magic wand + select white + delete?). This will for most editors introduce an alpha channel in your pixels and TouchGFX image converter will interpret this and generate pixel data for an ARGB8888 image.
/Martin
2 REPLIES 2
Martin KJELDSEN
Chief III
/Martin
Trevor Jones
Senior
will work with that, thanks
