STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
32F429IDISCOVERY LCD ILI9341 driver
Posted on March 19, 2015 at 15:17Hi,I would like to ask if anyone has successfully changed the setting of the ILI9341 driver to little endian...I have data in this format but in default I have to send over SPI high byte first and low byte after that...
Memory management - DCMI, OV7670, DMA, Grey color
Posted on March 21, 2015 at 22:11Hello! First of all there is worth to mention that I have successful communication with OV7670 camera on STM32F407VG Discovery and I getting QCIF format picture in YCbCr format and sending it via USB to computer as v...
sawingor by Associate II
  • 1762 Views
STM32F407VG working lcd library
Posted on March 11, 2015 at 21:16Hi, i'm looking for working LCD library for ks0108/s6b0108.All what i tested wasn't working well. Can someone help me? #ks0108 #stm32f4 #lcd #stm #lcd-l
STemWin VNC server compatibility
Posted on March 05, 2015 at 12:17HelloI am trying to use the STemWin library as a VNC server with a STM32F429 microcontroller.It works fine as long as I use a VNC client running on windows, for example UltraVNC.I have tested several VNC clients for ...
DCMI: pixel clock issues
Posted on February 18, 2015 at 12:59Hi GuysI' trying to get an image with DCMI module. So, I set up the camera sensor for a square test pattern (a grid of 16 white pixels and 16 black pixels). I get the data with the DMA and the grid obteined was 2x...
How to enable multi ADC using STM32F407ZG?
Posted on February 22, 2015 at 06:43I am using 2 ADC's ,1. for Touch Panel (ADC1)2. another for getting input from potentiometer (ADC3)Earlier Touch Panel program was working fine, when I implemented by initializing ADC3, there is a conflict, so the...
dhinesh by Associate
  • 1573 Views
UCOS porting problem
Posted on February 10, 2015 at 22:09HiI have the Problem: I have ported and tested a uCOSII on stm32f4/discovery(STM32f407VG) evaluation board with out any problem(board Programmed with onBoard STLINK).after that i have tried to program a custom boa...
STemWin GUI_Init() crashed
Posted on July 29, 2013 at 13:43Hi, I have Downloaded STemWin from the STM Website and i have tried to build a simple ''Hello World'' Application on my STM32F207 with KEIL 4.72a, but my Application goes into an infinite Loop in GUI_INIT(). I have fo...
mail2 by Associate II
  • 5410 Views
  • 17 replies
STM32F439XX with video and external framebuffer
Posted on January 13, 2015 at 20:32I can't seem to find more information on this, even looking through the EVAL code...here it goes:  I am designing a simple system to learn how to use the STM32F439XX and perhaps use it in future projects, but I am ...
