STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
JPEG hardware encoder / decoder
Hi,It's written here that STM32H750 has a JPEG hardware encoder / decoder for faster GUI operations.Is there an example for how to use this?Basically I need to know what kind of JPEGs it supports (and how to encode to the right JPEG type), and how to...
AlaaM by Associate III
  • 765 Views
Configuring CubeMX to generate STEmWin graphics template project for the STM32F746_DISCOVERY using internal SRAM.
Hello everyone, @Nawres GHARBI​ I am Trying to Generate code for STM32f746 discovery board, using CUBEMX with STemWin library without used of External SDRAM.Code is build and compiled with Keil MDK ver5 but with No Luck, get display blank or white.[ ...
ZMohd.7 by Associate III
  • 668 Views
The widgets for STM32L4r9
Hi,how can i change color depth for QRCode widgets.My application template is STM32L4r9-Discovery which has a 24-bit screen ,but the QRCode widgets is 12-bit color depth.so i guess could i change QRCode widgets's color depth to 24-bit that i can use ...
Jack li1 by Associate III
  • 1768 Views
How to draw a line with finger?
Hi,How can i draw a line on my display touchscreen with my finger.I have used Graph widget before,but the coordinate point must be monotone increasing。Could i use the method for QrCode,and could you write an example for this。Thanks�?�?�?Best regards​
  • 1323 Views
