2019-02-21 10:59 PM
i use IAR in time limited demo version IAR workbench 8.33.3.20228 (shared compnent 8.2.3.5849)
I can't link the generated code from thouchGFX designer : i have the following errors :
Error[Li060]: module "AbstractPainter.o(touchgfx_core.a)" contains C++ code built for use with the (E)C++98 library. This code is not link compatible with the new (C++14) library.
Error[Li060]: module "Screen.o(touchgfx_core.a)" contains C++ code built for use with the (E)C++98 library. This code is not link compatible with the new (C++14) library.
Have you any idea of how to solve this ?
Thanks
best regards
2019-02-21 11:06 PM
it seems that we have to take project under \NSTD2F746_Disco\target\IAR8.xand not \NSTD2F746_Disco\target\IAR.
Is it correct ?
