STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Resolved! Place assert In external Flash.When load the "TextFlashSection",which place fonts in exteral flash,an hardFault occured.
Hi,all!I'm Using STM32f767 developing touchGFX applications .Using MDK5.By the following the guidence in "https://touchgfx.zendesk.com/hc/en-us/articles/205886201-Placing-Assets-in-Flash-Memory" placing the fronts in extern Flash. sct file config as...
cyneer by Associate II
  • 2193 Views
Designer crash
While trying to diagnose designer code generation errors I found that if I deleted by custom container it causes the designer to crash even though it is not used on any screen.have repeated three times if you want me to zip up the project and detail ...
Resolved! Sending values to Custom Container Widgets
Hello,I am using a custom container which is used in most of the screens as TopBar showing various details.The details are varied by using depending on the backend values of the system.Normally, we use Model-Presenter-View for communicating with back...
Ameya M by Associate III
  • 2323 Views
ExtendedZoomAnimationImage motion ends prematurely
I have a few images moving and zooming across the screen, however every once in a while the animation ends before it reaches its destination and throws off my indexing. Initially I thought it was a GPIO interrupt that was causing this, so I make sure...
Du1 by Senior
  • 1492 Views
TouchGFX Chip Resource Usage
Does any one have a list or link to documentation that out lines the Chip Resource usage of the Touch GFX library?Obviously it uses the LTDC and DMA, I am looking for the complete list.Thank You​
MEder by Associate III
  • 787 Views
