STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Resolved! Chinese keyboard widget
I need a chinese keyboard in my application, how should i load the chinese font library and display it on screen,note that i need ALL CHINESE
User.32 by Associate
  • 1513 Views
Porting EXC7200 H743_EVAL CPTC driver to FT5426.
Hi,I'm using a TFT with FT5426 capacitive touch controller. I want to port the H743I_EVAL board EXC7200 CPTC driver to the FT5426.But I can't find any programming manual for the EXC7200 to compare to the FT5426. Does anyone have the EXC7200 programmi...
Asantos by Senior
  • 953 Views
how to make some code be called on every button press
In my current project i need a buzzer buzz every time any button is pressed, in simulator i'm just using Beep(F,D); but i was looking for a better approach than paste the beep function inside every single function called by any button, besides that w...
Zui by Senior
  • 3036 Views
LTDC layer 1 offset
Hello,I used the below code from ST bsp Board : STM32F746-DISCO BSP_LCD_Init(); BSP_LCD_SetLayerWindow(0,50,50,200,200); BSP_LCD_LayerRgb565Init(LTDC_LAYER_1,(uint32_t)fb);I expected layer 1 should be off by 50 on both axes . but it started from x = ...
RN by Senior
  • 871 Views
porting Keil MDK workspace to STM32CubeIDE
Hi!Can anyone suggest method to port Keil MDK uvision 5 workspace into STM32CubeIDE as Keil MDK does not support external flash programming in debug environment used in the touchfgx examples for STM32F746G-Discovery. It is difficult to visualize ho...
