STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
How to use display ?
Hello everyone, I am newbie on stm32 (stm32373c-eval). I need help to use display. Can any one suggest me a link or full guide to use it.Thank you in advance....
Dkuma.13 by Associate II
  • 1478 Views
Is it possible JPEG HW decoder output as RGB565?
Hi,I would like to change the example JPEG_DecodingFromFLASH_DMA to decode the JPEG file data to a frame buffer in RGB565 and then send this buffer to a 320x240 SPI TFT display. Only using the internal SRAM of the STM32H743VI. Is it possible?
Asantos by Senior
  • 2126 Views
STM32F769I-Eval JPEG IMAGE capture using DCMI.
We are using STM32F769I-Eval for capturing IMAGE in jpeg format using DCMI. we are able to run In-built example of storing image in bmp format,bmp to jpeg image conversion.From our understanding,it is going through RGB565- ARGB888- RGB888 ,then bmp h...
Tp by Associate II
  • 832 Views
When are invalidated areas re-rendered?
I am running an experiment to try to see how I can improve RENDER_TIME performance. In this experiment I have two items on the screen close to each other on the screen.One is a circle who's start and end angles are changed. The other item is a text ...
scottSD by Lead
  • 2853 Views
Resolved! cubemx error
Use cubemx to generate touchgfx, open vs file compilation, error occurs
lxw by Senior
  • 1676 Views
