STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
TouchGFX Low power consumption
Hello,I am making an application using Stm32f429 disco board and my question is:Do you have any solutions for low power consumption,for example, could I change brightness or turn off backlight in the running application?Thank you,Anton
qqAnton by Senior
  • 1036 Views
STM32F4 DCMI with SDIO
I am attempting to implement a system which uses a 5MP camera to take photos using DCMI and save them to an SD card via SDIO. When reading through the documentation there where a few things I was unclear of. I know between the SDIO interface and the ...
ACram by Associate
  • 1146 Views
STM32F769I ,Conversion from BMP to JPEG
We are using STM32F769I eval board for storing the image to USB using the example "Camera_To_USBDisk" , when we are trying to convert the image format from BMP to JPEG . The image does not open . We are following the JPEG frame format for conversion...
SNNV by Associate II
  • 844 Views
Where to implement general behavior
Hi there,I understand the MVP architecture and I like it. However I'm not sure where to implement event handling that shall be always active. E.g. an alarm event occurs and regardless the current screen, the application shall switch to a specific ala...
mattstein by Associate II
  • 1400 Views
