STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Remapping DCMI pins in f746 discovery board
Hi,I just started playing with STM32 tools and boards for my university thesis. Work would revolve around live video processing on an stm mcu. I am in possession of an stm32f746 discovery board, and was trying to hook up a camera (ov 7670) to it.But,...
AAnci.1 by Associate II
  • 1326 Views
Resistive touch calibration
HI,I have a stm32f769 custom board having 800*480 resolution RGB LCD. i am using tsc2003 touchscreen driver. i am able to port touchgfx and coulkd generate screens which are getting displayed without any issue. now i am trying to configure the touchs...
Changing to a different display
Hi everyone,I'm using the STM32F429 discovery board which comes with an LCD display. I tried out some example keil projects and also made some projects on TouchGFX software with hardware integration. All was working fine. I also have a different dis...
artifacts in 32-bit SDRAM
Helllo!I use development board with F769 and 32-bit sdramI see artifacts - stripes on both sides of picturesArtifacts a dissapear when I use 16 bit SDRAM mode. Artifacts are disappear then I use RBG565But I want 32-bit SDRAM and RGB888What I try to d...
EEuge by Senior
  • 1718 Views
Hi I have been using 480x272 Resistive display in my TouchGFX project The project has been created using CubeMx for STM32F746G discovery board controller We have used the stm32f746G board display configuration for Resistive display.
While running of resistive display,some oscillations on the texts appeared on the screenSometimes noise came on display.I have attached the video that shows the display noiseCapacitive touch parameters(Vsync,Hsync) have been used for Resistive touc...
STM-User by Associate II
  • 1409 Views
Touch on STM32F469 Discovery is not working in example programs, is there any hardware/driver update to know about?
Hi! I programed my usual code to the newer batch of STM324F69 Discovery but the touch capability of the screen is not responding. Out of the box the example program works fine, but when i Program the button example the touch doesnt works. This same b...
