STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
TouchGFX modelListener handling in Model::tick()
Hi,I'm trying to make an simple TouchGFX application that update a TextArea. But when i try to call, from Model::tick(), the modelListener pointer and access to the ViewPresenter function, it is not available. So i have probably misunderstanded some...
Woula by Associate II
  • 1696 Views
LCD.blitCopy parameters.
Can anyone explain to me what the parameters to LCD.blitCopy are?The online help seems to suggest all of the parameters describe the source - sourceData, sourceFormat, source and blitRect all describe the source data. How do I specify the destinatio...
FTkal.1 by Associate II
  • 1860 Views
Dear ST Community, i tried sometimes but still unsuccessful. can you all provide the STM32H750B-DK , with toughgfx step by step how to set by STMcubeMX, and compile ,programming, verify,debug by Keil procedure. Just want download simple image and run it .
Dear ST Community, i tried sometimes but still unsuccessful. can you all provide the STM32H750B-DK , with toughgfx step by step how to set by STMcubeMX, and compile ,programming, verify,debug by Keil procedure. Just want download simple image and run...
KLau.1 by Associate II
  • 3979 Views
MoveAnimator setMoveAnimationEndedAction issues
I am trying to set a callback function for a container in motion using setMoveAnimationEndedAction . Can I only use this functionality from within a container?I have created a custom object that has a member variable Container which is utilizing the...
