STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
error about creating an ui template
Hi, When I was creating a UI template before format my laptop, it was ok. But now, When I was trying to create an ui temp, I got the error like object reference not set to an instance of an object. What is the problem?
Ezgi by Senior
  • 1254 Views
DSI strange behavior
Hi st community members,I'm having some stranges behaviors with the DSI and LTDC, I use these peripherals to communicate with my screen driver. The driver need an init to give specific values for some registers, this step is well done.After that i'm ...
MLamb.1 by Associate II
  • 6482 Views
Resolved! Display and Update Table using TouchGFX
I am using TouchGFX 4.16.1 and i will be using 800x480 display. I want to use table on display. I have 5-6 Parameter and has 50 entries total. So for this i want to use table to display the data. Is there any widgets or method to display table?Here i...
SS.Sagar by Associate III
  • 2157 Views
Resolved! 3 buttons with image
Thank you for helping.environment:TouchGFX Ver 4.16.1Prepare two released images and one pressed image.While pressed, the pressed image is displayed.I want to switch the image of the released image every time the button is pressed and released.How sh...
Ebun.1 by Senior
  • 1256 Views
Resolved! How to add several include path to TouchGfx simulator
Hi,I cannot figure out how to add several include path to for the simulator.I can add 1 path to the TouchGFX\simulator\gcc\Makefile as follow:project_path := $(call qs,$(abspath $(call sq,$(makefile_path)../../..))) app_path := $(call qs,$(abspath $(...
