STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Resolved! The problem of touchgfx transplantation of stm32l4r9
(1) The GUI displays an exception. The problem can not be determined. It is suspected that the data sent by dma2d is incorrect. At present, there is no touchgfx fill interface function???(2) Close the GUI display function, directly call the bottom dm...
Zlian.1 by Associate II
  • 2571 Views
Problem with QSPI and TOuchGFX
Hello!I have homemade board with STM32F746, memory - n25q128.Project generated by Cube 5.5 and touchGFXDesigner 4.13 IDE - KEil 5.29I put one button to main screen.When I put images to internal flash - all works very well.But when I put it to QSPI - ...
EEuge by Senior
  • 2116 Views
TOUCHGFX4.16.1 run target failed
...  Compile       make -f ../gcc/Makefile -j8       Reading TouchGFX/application.config       Linking TouchGFX/build/bin/target.elf       Producing additional output formats...         target.hex  - Combined internal+external hex         intflash.el...
dchen.2 by Associate
  • 1645 Views
Hello, I am developing an application of about 20 screens I am trying to find a solution to this problem: how to call a general error screen without having to do it in the code of each screen
I am trying to find a solution to this problem: how to call a general error screen (application hardware failure) from my RTOS code without having to do it in the code of each screen ?Thanks for any clue or solution
SCAYL.1 by Associate
  • 1150 Views
