STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Resolved! Korean output not working using Unicode::snprintf()
Hello,I want to print Korean in <value> of wild cardThe encoding used in CubeIDE is attached as a picture file.The touchGFX version we use is 4.16​.​The initial value entered in wildcard is normally output as "정지".​(textArea and Typographies images a...
Hwoo- by Associate II
  • 3535 Views
Box with alpha does not work anymore
Hi!Since upgrading to TouchGFX 4.17, a box with an Alpha value does not work anymore. It just paints like as an opaque box, but not like a (semi-)transparent box.Thus I tried to create my own widget that draws a rectangle with the following code:HAL:...
STM32H747_DISCO design display issue
Had to redesign my STM32F769 design take the STM32H747 (silicon supply issues). So I cloned the H747_DISCO pin for pin with the exception that I've no external Flash. I then built a TouchGFX test app based on the H747_DISCO, removed the QSPI need in ...
Bruce1 by Associate
  • 756 Views
