STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Test Framework
Hi TouchGFX team,I'm in dire need of a test framework for my TouchGFX projects, and I've heard that you already make use of an internal version that allows you to step through a program frame by frame. That would be really useful!Do you plan on relea...
Örjan by Associate
  • 4530 Views
TouchGFX BoxWithRoundedCorner and Border
 Hi Team,I hope this message finds you well. I wanted to inquire if the TouchGFX team has any plans to introduce a BoxWithRoundedCorner widget in TouchGFX Designer.I’ve created a custom implementation on my end, but managing multiple widgets has prov...
TouchGFX build fails
when i run on touchgfx but with cubeide when i build there isn't error : gcc/makefile_cm7:503: recipe for target 'CM7/TouchGFX/build/Riverdi_70STM32H7/CM7/TouchGFX/target/generated/TouchGFXGeneratedHAL.o' failedmake[3]: *** [CM7/TouchGFX/build/Riverd...
Aziz by Associate II
  • 1839 Views
Framebuffer shifts across the screen in runtime
I am using similar hardware to the stm32f469i-disco however the screen is a st7701 and is ran in video mode (burst mode) with double buffer.I have added a video below showing the issue, for context the framebuffer doesn't shift with quick interaction...
JSime.1 by Associate II
  • 2614 Views
LTDC and Partial FrameBuffer Strategy
I have a STM32H7B3 Discovery Kit.To free up RAM for my application I tried to configure the PartialFramebaffer.Compilation fails with the following error message:undefined reference to `touchgfxDisplayDriverTransmitActive'The question is: is it possi...
QuiQuipu by Associate II
  • 4095 Views
