STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Add numeric keypad display
I'm just starting to use touchGFX and am trying to figure out the best way to design the functionality I need. I need a numeric input panel along with a display of the number that was entered. I need 10 digits (0-9), decimal point, a backspace, and a...
Touchgfx Numeric Keypad
I would like to enter password through numeric keypad. But could not find any example with numeric keypad. Since my display size is limited 320x240 pixels, alpha numeric may not be easy to use, any body has implementation for numeric keypad for quick...
YSN by Senior
  • 3039 Views
is there any GUI Tool for STM32H523?
Hi, therewe will start a project which will use STM32H523 as MCU, to control a LCD.first, we want to know, is there any GUI tool which can help us to build LCD display contents, then generate codes fot STM32H523?and do you have any sample project usi...
memory limit question
There was an issue where the screen froze due to too many packages. Is there a way in TouchGFX to check the memory limit for a screen and the amount of memory each package uses to evaluate the number of packages that can be used?
yu_jay by Associate II
  • 2339 Views
Administrator access for TouchGFX
Hi there Touchgfx team,Touchgfx can not run simulator or generate code on my Win11 laptop. I found out that touchgfx needed administrator access to have those function in Win11, but Win10 not. Because my laptop is for working and provided by my compa...
Resolved! TouchGFX and FDCAN integration
Hi all,I am trying to use the STM32H735G-DK as a Dashboard/Speedometer for a car project. However, I am having trouble integrating the FDCAN with the GUI. I have tried building the FDCAN code first then generating the GUI and vice versa.The Board is ...
Rowzee by Associate
  • 1766 Views
Riverdi RVT70HSSNWC00-B Problems
Purchased 5 RVT70HSSNWC00-B displays from RiverDi. Can not get even the demo project working on them from touchgfx or anything, and it is very frustrating. Has anyone know a fix or had a similar experience?
manas-fe by Associate
  • 2319 Views
