STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Resolved! Changing from LCD16bpp to LCD8bpp
Hello, I am facing an issue where the rendered frame buffer is printed on the display as gibberish pixels.I'm using the Nucleo F746ZG and interfacing it (over SPI) with an external display controller that writes to a 240*320 display. I was not able t...
bornamm by Associate II
  • 5203 Views
Bug report: Wildcard use and swapping text.
Hello,I found an "edge" case with TouchGFX Designer.I have a message box that can swap syntax between language and wildcard count.think of:-ID1: "Clock stop"-ID2: "Clock <min>"-ID3: "Clock <sec>.<usec>"I was able to set a base class with id3 and both...
Marc_LM by Senior
  • 934 Views
How to know the active screen from model.cpp
I would like to check which screen is activated from model.cppI tried to use getCurrentScreen() in touchgfx::Applicationhttps://www.touchgfx.com/documentation/html/classtouchgfx_1_1_application_af560e49a149b6d2d0ccffd4ca42e5991.html#af560e49a149b6d2d...
COSEBE by Senior
  • 4336 Views
  • 7 kudos
Resolved! Callbacks between container and view
Hi, I went through some other discussions discussing a similar problem, but they did not seem to help. I have screen one which displays (dynamically) a container. The container has a button on it, which when clicked, changes screens to screen 2. At t...
Priyank by Senior
  • 5393 Views
  • 13 replies
Resolved! Whether Video is support in STM32U5 controller?
Hi,I am having STM32U575 boards with me and I am able to use a simple TouchGFX project with U575ZI_GFX02Z1 example from TouchGFX.I tried embedding example Video from TouchGFX and my compilation fails for the below error:(.text._ZN8touchgfx11VideoWidg...
mdalal by Associate III
  • 1109 Views
