2023-02-15 6:22 AM
hi all,
I would like to experiment with the TFM applications contained in the STM32CubeU5 package on my B-U585I-IOT02A board
unfortunately, it seems that STM32CubeIDE is not supported
does anyone have suggestions on how to build the TFM applications, based on free and/or open software, without the need to install trial versions of EWARM?
thanks in advance
Gianluca
2023-02-17 12:51 AM
2023-02-17 12:51 AM
2023-02-27 2:46 AM
hello @Mohamed Aymen HZAMI
I've downloaded the new version of the package STM32CubeU5 and indeed now it contains STM32Cube IDE projects for both Secure and NonSecure TFM Appli
unfortunately, they do not build!
I attach the errors I get when I try to build the projects
thank you in advance,
Gianluca
2023-02-28 1:49 AM
UPDATE: I was able to solve by manually running the script prebuild_s.sh in the TFM_Appli_Secure project
would still appreciate a feedback from ST
thanks,
Gianluca
2023-04-07 1:32 AM
Hello @GTort.1,
We confirm that the issue you encountered is related to prebuild_s.sh script was not correctly executed.
So, you found the right workaround by executing the script manually.
The compilation is well executed on our side and we do not face this issue.
Could you give you precise your environment and the STM32CubeIDE version?
Mohamed Aymen
