SBSFU : how to remove write protection?
ANaga.2
Associate II
I forgot to comment the protections set in app_sfu.h and tried debugging the code.
Later I realized and commented everything and it is not allowing me to flash the program on the device.
I made RDP level 0 from cube programmer, but still write protection is enabled which is not allowing me to format the device.
Could anyone please let me know how can i remove write protections in cube programmer.
Thanks,
Ankush
1 ACCEPTED SOLUTION
Accepted Solutions
Hi @ANaga.2​
Please try this command" -c port=swd -ob displ "then tell me the output to check the issue.
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer-2.5.0\bin>STM32_Programmer_CLI.exe -c port=swd -ob displ
            STM32CubeProgrammer v2.5.0
ST-LINK SN : 0669FF303435554157042733
ST-LINK FW : V2J30M19
Board    : NUCLEO-L476RG
Voltage   : 3.26V
SWD freq  : 4000 KHz
Connect mode: Normal
Reset mode : Software reset
Device ID  : 0x415
Revision ID : Rev 4
Device name : STM32L4x1/STM32L475xx/STM32L476xx/STM32L486xx
Flash size : 1 MBytes
Device type : MCU
Device CPU : Cortex-M4
UPLOADING OPTION BYTES DATA ...
 Bank     : 0x00
 Address    : 0x40022020
██████████████████████████████████████████████████ 100%
 Bank     : 0x01
 Address    : 0x40022044
OPTION BYTES BANK: 0
  Read Out Protection:
   RDP     : 0xAA (Level 0, no protection)
  BOR Level:
   BOR_LEV   : 0x0 (BOR Level 0, reset level threshold is around 1.7 V)
  User Configuration:
   nRST_STOP  : 0x1 (No reset generated when entering Stop mode)
   nRST_STDBY  : 0x1 (No reset generated when entering Standby mode)
   nRST_SHDW  : 0x1 (No reset generated when entering the Shutdown mode)
   IWDG_SW   : 0x1 (Software independant watchdog)
   IWDG_STOP  : 0x1 (IWDG counter active in stop mode)
   IWDG_STDBY  : 0x1 (IWDG counter active in standby mode)
   WWDG_SW   : 0x1 (Software window watchdog)
   BFB2     : 0x0 (Dual-bank boot disable)
   nBOOT1    : 0x1 (Boot from Flash if BOOT0 = 0, otherwise system memory)
   SRAM2_PE   : 0x1 (SRAM2 parity check disable)
   SRAM2_RST  : 0x1 (SRAM2 is not erased when a system reset occurs)
  PCROP Protection (Bank 1):
   PCROP1_STRT : 0xFFFF (0x807FFF8)
   PCROP1_END  : 0x0 (0x8000000)
   PCROP_RDP  : 0x0 (PCROP zone is kept when RDP is decreased)
  Write Protection (Bank 1):
   WRP1A_STRT  : 0xFF (0x807F800)
   WRP1A_END  : 0x0 (0x8000000)
   WRP1B_STRT  : 0xFF (0x807F800)
   WRP1B_END  : 0x0 (0x8000000)
OPTION BYTES BANK: 1
  PCROP Protection (Bank 2):
   PCROP2_STRT : 0xFFFF (0x80FFFF8)
   PCROP2_END  : 0x0 (0x8080000)
  Write Protection (Bank 2):
   WRP2A_STRT  : 0xFF (0x80FF800)
   WRP2A_END  : 0x0 (0x8080000)
   WRP2B_STRT  : 0xFF (0x80FF800)
   WRP2B_END  : 0x0 (0x8080000)
Best regards,
Nesrine
5 REPLIES 5
Hello @ANaga.2​ ,
Could you please give me more details about the Board name used .
Best regards,
Nesrine
ANaga.2
Associate II
Its L476RG
Hi @ANaga.2​
Voltage   : 3.26V
SWD freq  : 4000 KHz
Device ID  : 0x415
Revision ID : Rev 4
Device type : MCU
 Bank     : 0x00
 Bank     : 0x01
  BOR Level:
  User Configuration:
Best regards,
Nesrine
ANaga.2
Associate II
It worked. Thank you so much
jarus0
Associate II
Hello everyone, We were testing out the SBSFU example for our 2 running projects.
But currently, we are unable to upload any other program to the device.
Here is the STM32CubeProgrammer log for "Full chip erase" request
  15:26:43:686 : MASS ERASE ...
  15:26:43:693 : Flash erase...
  15:26:43:694 : halt ap 0
  15:26:43:716 : Init flashloader...
  15:26:43:716 : halt ap 0
  15:26:43:718 : run ap 0
  15:26:43:735 : halt ap 0
  15:26:43:735 : Loader mass erase...
  15:26:43:737 : run ap 0
  15:26:43:737 : halt ap 0
  15:26:43:737 : Error: Mass erase operation failed.Please verify flash protection
And below CLI output is given
Please have a look and suggest us to resolve this.
Thanks
./STM32_Programmer_CLI -c port=swd -ob displ
                        STM32CubeProgrammer v2.12.0
ST-LINK SN  : 0671FF313736504157192620
ST-LINK FW  : V2J40M27
Board       : NUCLEO-G070RB
Voltage     : 3.23V
SWD freq    : 4000 KHz
Device ID   : 0x460
Revision ID : Rev B
Device name : STM32G07x/STM32G08x
Flash size  : 128 KBytes
Device type : MCU
Device CPU  : Cortex-M0+
BL Version  : 0xB2
Debug in Low Power mode enabled
  Bank          : 0x00
[==================================================] 100%
   BOR Level:
     BOR_EN       : 0x0 (Configurable brown out reset disabled, power-on reset defined by POR/PDR levels)
     BORR_LEV     : 0x0 (BOR rising level 1 with threshold around 2.1 V)
     BORF_LEV     : 0x0 (BOR falling level 1 with threshold around 2.0 V)
   User Configuration:
     RAM_PARITY_CHECK: 0x1 (SRAM parity check disable)
     nBOOT_SEL    : 0x1 (BOOT0 signal is defined by nBOOT0 option bit)
     nBOOT0       : 0x1 (nBOOT0=1)
     NRST_MODE    : 0x3 (Bidirectional reset: NRST pin configured in reset input/output mode (legacy mode))
     IRHEN        : 0x1 (Internal resets drives NRST pin low until it is seen as low level)
   PCROP Protection:
     PCROP1A_STRT : 0xFF  (0x801FE00)
     PCROP1A_END  : 0x0  (0x8000200)
     PCROP1B_STRT : 0xFF  (0x801FE00)
     PCROP1B_END  : 0x0  (0x8000200)
   Write Protection:
     WRP1A_STRT   : 0x0  (0x8000000)
     WRP1A_END    : 0x1F  (0x800F800)
     WRP1B_STRT   : 0x3F  (0x801F800)
   FLASH security:
     BOOT_LOCK    : 0x0 (Boot based on the pad/option bit configuration)
     SEC_SIZE     : 0x20  (0x8010000)
